Anyone know what to do if an axle won't go smoothly into the hub splines?
On my driver side the axle slides in and out of all the hubs I have without any issues, I can do it by hand smooth like butter.
The passenger side axle though I had to use a puller to push the axle out of the old hub. Wasn't super hard but I couldn't pull it out by hand like the driver side. Now when I'm putting everything back together with a hew hub the axle goes on the splines maybe 1/4 inch then stops enough so that I can't push it in by hand.
I'm pretty sure it has something to do with the axle. Like I said, my driver side axle will slide easily into all 4 of the hubs I have (2 old and the 2 new). Passenger side just won't go easily into any hub. It is going on the splines but then it gets stuck. I have anti-seize on the axle and have tried bearing grease too, neither helped.
??? I'm lost here. Do I need a new axle or is there some way to push that sucker into the hub?
