gonna tap a new hole im so irritated with this
agreeing with Tom, this don't look like an escape. I would suggest using a self tapping bolt, it is only securing the cover, there is no pressure involved.gonna tap a new hole im so irritated with this
I like new tools. I might have to buy one of these. ( :Iv'e used it and it works. RESCUE BIT LLC
It's a little pricey, but it works. No lubrication and start the job at full speed. The tool eats easy-outs without problem.I like new tools. I might have to buy one of these. ( :
You don't need them often, but when you do, they are gold in hand.
I have worked at easy outs for hours, trying to get them out, and usually wound up with a cut off wheel, or grinder… I have also had luck, hitting the side of the easy out/nut with a ball peen, and getting it to shock back up out of the hole.It's a little pricey, but it works. No lubrication and start the job at full speed. The tool eats easy-outs without problem.
