1 - 3 of 3 Posts
well this is kinda instresting.
has anyone doen this or know if it will work on the avh p4200dvd. also how would you add an amp or amps to the system with this setup
The bypass is the same for the 4200. Adding an amp is simple. Power the amp from the battery, run rca cables from the amp to the hu, and then run speaker wires from the amp to the speaker. Voila.
Thanks for posting that - I have a 4100 that will be going in my '01 (was in my '07 stang) & was trying to figure out a way to bypass it without a switch.
1 - 3 of 3 Posts
