Hello Everyone,
Today I recieved my cabin air filter. There's only one problem. When I went to install it, it didn't fit. I checked the part number on the filter and according to many websites, it's the correct part number. It's TYC 800037P. I am wondering if there is a different housing that can be purchased so that I can install the filter. The one that's in there now is a triangle shaped housing with a screen on one side.
My escape did not come with a factory installed filter.
Thanks
Don
[mod]Moved to Problems And Solutions[/mod]
Ford modified the HVAC system around the 2007 model year to address an airflow issue, but it seems as if they forgot to update their parts catalogs. If you have a triangle/trapezoid opening, the filter you are looking for should be the 8L8Z-19N619-B, Motorcraft P/N FP-66.
http://www.rockauto.com/catalog/raframe ... =NT48-FP66
As an alternative, you can buy a piece of washable "lifetime" furnace filter material and cut it to fit your opening.
Hopefully the new part number works out. You might want to go to a physical retailer the first time, even if it is more expensive. That way you can easily return it without added shipping charges if it doesn't fit.
