Here you go, Scott.
Vehicle History
Report™
Vehicle
Highlights™
Warranty
Check™
Safety & Reliability
Ratings™
Buyback Guarantee™
Certificate
Consumer Ratings
& Comments™
For Personal Use Only Print This Page • Print All Pages
Loading...
Rebuilt/Reconstructed Title
A Rebuilt/Reconstructed vehicle is a salvage vehicle that has been repaired and restored to operation. These vehicles are often severely damaged before they are rebuilt and refurbished parts are typically used during reconstruction. In most states, an inspection of the vehicle is required before the vehicle is allowed to return to the road. Manufacturer Buyback or Lemon
A DMV or a state agency marks an official document or issues a Manufacturer Buyback/Lemon title when a vehicle has been repurchased by the manufacturer. Not all states issue manufacturer buyback titles and the specific requirements for a lemon law vehicle varies by state. Odometer Rollback
If a more recent odometer reading is less than an older reading, then the odometer may have been tampered with and "rolled back". Manufacturer Recall
Automobile manufacturers issue recall notices to inform owners of car defects that have come to the manufacturer's attention. Recalls also suggest improvements that can be made to improve the safety of a particular vehicle. Most manufacturer recalls can be repaired at no cost to you. Basic Warranty
Most manufacturers offer a basic warranty for new vehicles. These warranties vary by manufacturer and typically last for a certain amount of time and/or a set number of miles. Not Actual Mileage Title
When the seller certifies, under the Federal Odometer Act, that the odometer reading does not reflect the vehicle's actual mileage. This may occur because the odometer was tampered with, broken, or replaced. Junk Title
A Junk Title is issued on a vehicle damaged to the extent that the cost of repairing the vehicle exceeds ~ 75% of its pre-damage value. This damage threshold may vary by state. The majority of states use this title to indicate that a vehicle is not road worthy and cannot be titled again. Some states treat Junk titles the same as Salvage. Loss Due To Fire Title
The vehicle sustained major damage due to fire. In most states, fire damage titles are issued when the cost of repairing the vehicle for safe operation exceeds its fair market value. Exceeds Mechanical Limits
A vehicle with a 5-digit odometer cannot accurately track mileage after 99,999 miles because the odometer rolls over. This title is the result of a seller certifying under the Federal Odometer Act, that the odometer reading EXCEEDS MECHANICAL LIMITS of the odometer. Structural / Frame Damage
In most cases, a vehicle is inspected for structural or frame damage, depending on the body design, after an accident or other incident. All levels of accidents from minor to severe can cause structural / frame damage and in most cases it can be repaired. Airbag Deployment
Occurs when the driver, passenger or side airbag has been used or deployed during a crash or other incident. If an airbag has been deployed, it must be replaced by a qualified technician. Have this car inspected by a mechanic prior to purchase. Salvage Title
A Salvage Title is issued on a vehicle damaged to the extent that the cost of repairing the vehicle exceeds ~ 75% of its pre-damage value. This damage threshold may vary by state. Some states treat Junk titles the same as Salvage but the majority use this title to indicate that a vehicle is not road worthy and cannot be titled again in that state. The following eleven States also use Salvage titles to identify stolen vehicles - AZ, FL, GA, IL, MD, MN, NJ, NM, NY, OK and OR. Total Loss
An insurance or fleet company declares a vehicle a total loss when a claim exceeds ~ 75% of its pre-damage value or if the vehicle is stolen and not recovered. This damage threshold varies by company. These companies typically take possession and obtain the title. Not all total loss vehicles result in a DMV-reported branded title, like a Salvage or Junk title. See the glossary for more information. Accident Indicator
Various events could indicate an accident in a vehicle's history, such as: salvage auction, fire damage, police-reported accident, crash test vehicle, damage disclosure, collision repair facility and automotive recycler records. See the glossary for more information. Hail Damage Title
The vehicle sustained major damage due to hail. In most states, hail damage titles are issued when the cost of repairing the vehicle for safe operation exceeds its fair market value. Flood Damage Title
States issue flood titles when a vehicle has been in a flood or has received extensive water damage. Standard Equipment
Power Steering, AM / FM CD, Power Brakes, Removable panels, Tilt Wheel, 6-digit Odometer Safety Options
4 Wheel ABS Optional, Dual air bags front/active (manual) belts with passenger side deactivation switch
2000 JEEP WRANGLER SAHARA/TJ SAHARA
1J4FA59S8YP803046
2 DR WAGON SPORT UTILITY
4.0L L6 MPI / 4 WHEEL DRIVE
Standard Equipment | Safety Options
Hi-I'm the CARFAX Xpert™. I'm here to help you better understand the data in this CARFAX Report. Did you know...
We checked over 5 billion records from thousands of data sources for this vehicle
This vehicle qualifies for the CARFAX Buyback Guarantee
The last reported odometer reading was 64,266
A CARFAX Vehicle History Report is based only on information supplied to CARFAX. Other information about this vehicle, including problems, may not have been reported to CARFAX. Use this report as one important tool, along with a vehicle inspection and test drive, to make a better decision about your next used car.
The number of owners is estimated by CARFAX Owners 1-3 Owner 4 Owner 5
Year purchased 2000 2005 2006
Type of owner Personal --- ---
Estimated length of ownership 4 yrs. 4 mo. 5 months 2 yrs. 2 mo.
Owned in the following states/provinces Colorado Colorado, Indiana Indiana
Estimated miles driven per year 12,045/yr --- ---
Last reported odometer reading 53,616 64,266
CARFAX guarantees the information in this section Owners 1-3 Owner 4 Owner 5
Salvage | Junk | Rebuilt Guaranteed
No Problem Guaranteed
No Problem
Fire/Flood | Hail Damage | Buyback/Lemon
Guaranteed
No Problem
Not Actual Mileage | Exceeds Mechanical Limits Guaranteed
No Problem
GUARANTEED - None of these major title problems were reported by a state Department of Motor Vehicles (DMV). If you find that any of these title problems were reported by a DMV and not included in this report, CARFAX will buy this vehicle back.
Register | View Terms
Not all accidents or other issues are reported to CARFAX Owners 1-3 Owner 4 Owner 5
Total Loss Check
No total loss reported to CARFAX. No Issues Reported
No Issues Reported
No Issues Reported
Structural / Frame Damage Check
No structural / frame damage reported to CARFAX. No Issues Reported
No Issues Reported
No Issues Reported
Airbag Deployment Check
No airbag deployment reported to CARFAX. No Issues Reported
No Issues Reported
No Issues Reported
Odometer Rollback Check
No indication of an odometer rollback. No Issues Indicated
No Issues Indicated
No Issues Indicated
Accident Check
No accidents reported to CARFAX. No Issues Reported
No Issues Reported
No Issues Reported
Manufacturer Recall Check
No open recalls reported to CARFAX. No Recalls Reported
No Recalls Reported
No Recalls Reported
Basic Warranty Check
Original warranty estimated to have expired. View Info
Interested in an extended warranty? Warranty Expired
Warranty Expired
Warranty Expired
Tell us what you know about this vehicle
Still looking? Find similar cars just listed for sale in your area.
Let us do the work! Get daily updates of JEEP WRANGLER vehicles for sale in your area.
Email:
Zip:
2000 JEEP WRANGLER SPORT/TJ SPORT Listed 21 hours ago
Body Style: 2 Dr Wagon Sport Utility
Engine Type: 4.0L L6 MPI
Standard Equipment: Power Steering, AM / FM Cassette, Power Brakes, Removable panels, 6-digit Odometer
Free CARFAX Report Hampton Imports
850-244-8600
Distance: 43.17 mi
View Dealer Inventory
Contact Dealer
2001 JEEP WRANGLER SPORT/TJ SPORT
Free CARFAX Report Lloyd Nissan
Distance: 18.37 mi
Contact Dealer
A CARFAX Vehicle History Report is based only on information supplied to CARFAX. CARFAX checked over 5 billion vehicle history events and found 28 record(s) for this 2000 JEEP WRANGLER SAHARA/TJ SAHARA (1J4FA59S8YP803046).
Owner 1
Purchased: 2000
Type: Personal
Where: Colorado
Est. miles/year: ---
Est. length owned: 9/20/00 - 5/29/03
(2 yrs. 8 mo.)
Date: Mileage: Source: Comments:
09/20/2000 Colorado
Motor Vehicle Dept.
Denver, CO First owner reported
Registered as
personal vehicle
05/24/2002 Colorado
Motor Vehicle Dept.
Denver, CO Registration updated when owner moved
the vehicle to a new location
08/26/2002 Colorado
Motor Vehicle Dept.
Denver, CO
Title #166747 Title issued or updated
Loan or lien reported
Owner 2
Purchased: 2003
Where: Colorado
Est. length owned: 5/29/03 - 9/9/03
(3 months)
05/29/2003 Colorado
Motor Vehicle Dept.
Denver, CO
Title #689905 Title issued or updated
New owner reported
09/05/2003 40,471 Colorado
Inspection Station Passed emissions inspection
09/09/2003 40,477 Dealer Inventory
Denver, CO Vehicle offered for sale
09/12/2003 40,481 Dealer Inventory
Colorado Vehicle sold
Owner 3
Purchased: 2003
Where: Colorado
Est. length owned: 10/8/03 - 2/7/05
(1 yr. 3 mo.)
10/08/2003 Colorado
Motor Vehicle Dept.
Colorado Springs, CO
Title #706000 Title issued or updated
New owner reported
11/12/2004 Colorado
Motor Vehicle Dept.
Colorado Springs, CO Registration updated when owner moved
01/14/2005 52,369 Shortline Automotive
303-364-0225
http://www.shortlineauto.com
ww.shortlineauto.co
m Vehicle serviced
Pre-delivery inspection completed
Manufacturer's recommended maintenance performed
Engine checked
Washed/detailed
02/07/2005 Dealer Inventory
Aurora, CO Vehicle offered for sale
02/21/2005 Shortline Automotive
303-364-0225
ww.shortlineauto.co
m Vehicle serviced
Electrical
Engine/powertrain computer/module checked
02/26/2005 53,616 Shortline Automotive
303-364-0225
ww.shortlineauto.co
m Vehicle sold
Owner 4
Purchased: 2005
Where: Colorado, Indiana
Est. length owned: 3/24/05 - 9/18/05
(5 months)
03/24/2005 Colorado
Motor Vehicle Dept.
Aurora, CO
Title #279842 Title issued or updated
New owner reported
03/30/2005 Shortline Automotive
303-364-0225
ww.shortlineauto.co
m Vehicle serviced
04/11/2005 Colorado
Motor Vehicle Dept.
Aurora, CO
Title #279842 Registration issued or renewed
09/08/2005 Andy Mohr Buick Pontiac GMC Truck
Fishers, IN
317-632-6300
http://www.andymohr.com Vehicle serviced
Interior trim checked
09/18/2005 Dealer Inventory
Fishers, IN Vehicle offered for sale
09/20/2005 Dealer Inventory Vehicle offered for sale
11/04/2005 Andy Mohr Buick Pontiac GMC Truck
Fishers, IN
317-632-6300
12/24/2005 64,266 Indiana
Motor Vehicle Dept.
Fishers, IN
Title #05105248006 Title issued or updated
Dealer took title of this vehicle
while it was in inventory
12/27/2005 Andy Mohr Buick Pontiac GMC Truck
Fishers, IN
317-632-6300
02/11/2006 Andy Mohr Buick Pontiac GMC Truck
Fishers, IN
317-632-6300
http://www.andymohr.com Vehicle sold
02/13/2006 Andy Mohr Buick Pontiac GMC Truck
Fishers, IN
317-632-6300
03/24/2006 Andy Mohr Buick Pontiac GMC Truck
Fishers, IN
317-632-6300
Owner 5
Purchased: 2006
Where: Indiana
Est. length owned: 3/28/06 - present
(2 yrs. 2 mo.)
03/28/2006 Indiana
Motor Vehicle Dept.
Crawfordsville, IN
Title #06105470148 Title issued or updated
New owner reported
If you are buying this vehicle from a private seller, check to be sure any associated lien on the vehicle has been paid off.
06/16/2006 Andy Mohr Buick Pontiac GMC Truck
Fishers, IN
317-632-6300
07/25/2006 Andy Mohr Buick Pontiac GMC Truck
Fishers, IN
317-632-6300
Have Questions? Please visit our Help Center at
http://www.carfax.com
First Owner
When the first owner(s) obtains a title from a Department of Motor Vehicles as proof of ownership.
New Owner Reported
When a vehicle is sold to a new owner, the Title must be transferred to the new owner(s) at a Department of Motor Vehicles.
Ownership History
CARFAX defines an owner as an individual or business that possesses and uses a vehicle. Not all title transactions represent changes in ownership. To provide estimated number of owners, CARFAX proprietary technology analyzes all the events in a vehicle history. Estimated ownership is available for vehicles manufactured after 1994 and titled solely in the US including Puerto Rico. Dealers sometimes opt to take ownership of a vehicle and are required to in the following states: Maine, Massachusetts, New Jersey, Ohio, Oklahoma, Pennsylvania and South Dakota. Please consider this as you review a vehicle's estimated ownership history.
Title Issued
A state issues a title to provide a vehicle owner with proof of ownership. Each title has a unique number. Each title or registration record on a CARFAX report does not necessarily indicate a change in ownership. In Canada, a registration and bill of sale are used as proof of ownership.
Additional Services & Resources
Auto Loans - LendingTree InsWeb Auto Insurance Extended Warranty
CARFAX DEPENDS ON ITS SOURCES FOR THE ACCURACY AND RELIABILITY OF ITS INFORMATION. THEREFORE, NO RESPONSIBILITY IS ASSUMED BY CARFAX OR ITS AGENTS FOR ERRORS OR OMISSIONS IN THIS REPORT. CARFAX FURTHER EXPRESSLY DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING ANY IMPLIED WARRANTIES OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE. CARFAX®
© 2008 CARFAX, Inc., an R.L. Polk & Co. company. All rights reserved. Patents pending. 04.Jun.2008 11:09:01
2000 Jeep Wrangler Sahara/TJ Sahara
VIN: 1J4FA59S8YP803046
Body Style: 2 DR WAGON SPORT UTILITY
Engine Size: 4.0L L6 MPI
Drivetrain: 4 Wheel Drive
Original Manufacturer's Warranty:
Basic Warranty Expired
Please confirm remaining factory warranty and extended warranty options with your dealer!
The original manufacturer's warranty includes:
36 months or 36,000 miles
Information excerpted from the CARFAX Vehicle History Report and/or Safety & Reliability Ratings; see full reports for additional information, glossary of terms, source attributions,disclaimers & limitations. Go to carfax.com for complete Buyback Guarantee terms and conditions.
Number of Owners: 5
Last owned in the following state/province: Indiana
None of these major title problems were reported by a state Department of Motor Vehicles:
Salvage, Junk, Rebuilt Guaranteed
No Problem
Fire / Flood, Hail damage, Buyback / Lemon Guaranteed
No Problem
Not Actual Mileage,
No Problem
No issues reported to CARFAX on the following:
Total Loss
No Issues Reported
No Issues Reported
Airbag Deployment
No Issues Reported
Odometer Rollback
No Issues Reported
Other Accidents
No Issues Reported
http://www.carfax.com/phoenix/external/ ... Out=64,266 miles&lastCarfaxOdoDate=12/24/2005&vehicleVinPhrase=2000 JEEP WRANGLER SAHARA/TJ SAHARA (1J4FA59S8YP803046)&makeName=JEEP&makeLink=www.jeepunpaved.com&void=&dataAvailable=Y&summaryLine=No Coverage Remaining on Basic Warranty.&suppressed=&webSideStory=Warranty+Calculator+Recalc+Page&webSideStoryCategory=Reference+Help&partnerName=CFX&tabbedVhr=true&reliableOdo=normal
http://www.carfax.com/cfm/SRRDisplay.cf ... pressWss=Y http://www.carfax.com/manifest/bbg/view ... anguage=EN http://www.carfax.com/phoenix/external/ ... pressWss=Y
