REFERNECE'S
http://www.escape-city.com/viewtopic.php?f=28&t=1120
http://www.escape-city.com/viewtopic.php?f=28&t=484
http://www.cardomain.com/ride/3329314/3
(EXCUSE THE DETAIL SEQUENCE OF PICS, I WROTE THE WRITE UP AFTER THE PICS WHERE DONE SO I WROTE THIS TO BEST SUITE THE READER)
This is the write up for the center console and center cluster exchange.
1) Is to pull out the CENTER A/C vents. No trick to this, you that must be done is to get a good grip and pull straight out; this allows exposure to the upper bolt on the radio bezel.
2) Remove the power station (where the cigarette lighter is) same process as the AC VENTS. Get a good grip and then pull straight out. The trick here is slip your left thump in the socket and get a good grip with the other hand and pull straight out. This exposes the bolt bolts for the radio bezel.
3) Remove the bolts from the bezel and remove.
a. There will be connectors located on the back of the bezel that control the AC Remove those. The big one is the hardest and takes a big of muscle to pull out so be careful. The other is not so hard and requires a flip of a little handle located on it.
b. Make the switch from one bezel to the other.
4) Removing the ring from the shifter can be a little sketchy but look at the pic and be careful not to scratch the center console.
a. There are 4 tabs that hold it in try to pull on those sides to ensure a safe removal
5) Open the center console compartment and remove the center console bucket. This will allow for the center console to be removed. I placed myself on the driver side and got a good grip and pull straight up
6) Make the switch with the other console. By simply popping back in place.
7) While I had this open and don't have pics of; are the cables that are to run my sub and amp. Which I have ran but not yet found a place to secure the amp. But am currently enjoying.
8) Run everything backwards to reassemble
I have been trying to change or black out everything on the center console to piano black. But have been running into a lot of impedance. Being that I had to turn to spray painting the radio bezel, door handles and if I don't find the CENTER AC VENTS I will spray paint that as well. But the AC VENTS have a lot of curves and a lot of angles. SO this makes it harder to spray paint and give it an even coat. In order to give it the piano black look, one must give a generous coat of paint. Too much and then dripping occurs and uneven settling especially in the corners where it pits. It would make a small puddle.
