1 - 7 of 7 Posts
Does anyone have a guide for the current generation Escapes to pull up the center console? I want to do the USB2 hack, but I'm afraid of busting something in the process.
Thanks!
It's like Christmas -- thanks. Can't believe I couldn't find it earlier.
Is there a secret or trick to removing the console finish panel (item #4 on the diagram)? I have a 2011 and have tried pulling it straight up and it will not budge. I'm not being a wimp, but at the same time I do not want to bust it.
Thanks!
Thanks!
First time pulling most dash parts its "tight"
Thanks Urbangrunt,
Tight? You got that right! I did get it finally though. Part of the problem was my original technique (I wasn't pulling in the right spots) and I was also able to start it by gently prying things loose using a 2-inch putty knife with the blade wrapped in a couple layers of gaffer tape to provide some protection. No cracks, no pops, no errors. Have a good one.
Kurt
1 - 7 of 7 Posts
