Hi
I have a 2010 Mariner, 2.5L, 4WD Base
I had the struts, shocks, both lower control arms 4 wheel alignment , in the last couple of months.
There is the clonk noise whenever I drive from Right Front.
Not sure where it’s coming from
Can you maybe capture clonk audio? ( :
Conditions? are you accelerating like a grandma, are you hitting it hard getting onto the highway on-ramp making a turn? Turning in One Direction, but not the other? Manual transmission, or automatic?
Random clonk I would guess would be in exhaust mount, or something that has been worked on very recently
Motor mount?… We can guess all day
You're going to have to narrow it down, or put it up in the air, and start shaking things down. You seem pretty clear it's the right front end… Maybe even brake caliper? I don't know what all was touched when y'all worked on stuff.
That would be the first thing I shake down, is what has been most recently worked on.
I have made mistakes, I am human. It sucks to have to go back through everything.
you have to go through it all though
this is funny, but check and make sure nobody left a wrench, flashlight, beercan...
or anything that could be banging around… Hopefully it's something silly after all that work.
