2 quick questions relating to weather....
Tranny shifts late very often now that cold weather hits. When I bought the escape late May they said it did not need the software update. Any ideas?
Also, my MPG has tanked. From 24.8-26 mpg to 22.9-23.5. I expect some dip as I run the car sometimes to warm it up for a few. Is this due to oxygenated fuel? I can't seem to hit all 5 bars on the MPG graph when driving.
Otherwise cranking at 8700 mi. :)
Don't expect normal shifts until the vehicle has warmed. My Escape is stiff driving/shifting until the water(?) temperature hits 207F.
In addition, check your fluids. My trans fluid was only filled to half (there WAS a reason, flat-tow concern, but my driving doesn't ever require that) and once it was filled, things got much smoother. It was really, really clumsy until then.
Keep in mind that (1) snow tires, if any, will bump mileage, and (2) winter blend gas doesn't burn quite so efficiently. I've recovered some MPGs via overinflating my tires (and wear so far has seemed fine), but I won't go further than mentioning that.
Something else that has never been brought up about gas mileage and power; altitude. Different altitudes affect gas mileage and power. Example: I get better gas mileage at sea level than I do at an altitude of 3900 feet. I also have more power at sea level, due to the density of the air. Higher altitudes have less air density.
How very true!!!
On the average, every 3000ft of altitude results in 10% of power loss!
