A couple of months after I bought my 08 xlt I had an aftermarket alarm/remote start installed.
I've had 2 times in the past year where for some reason the factory alarm goes off(lights flash and horn honk) and it sets off the aftermarket system as well(maybe the aftermarket sets off the factory in some way, they just both end up going off). I can shut the aftermarket off easy enough with the long range remote but the factory alarm won't stop till it times out or I trot out there and use the key in the ignition.
Before I got the aftermarket system I wasn't able to set the factory alarm off in any way so I assumed it didn't have one and now I find myself wishing it didn't. I always lock the Escape with the remote from the aftermarket so it's nothing to do with the factory keyfob as far as I can figure. I've also checked the wiring listed for installing in the 08 and there isn't a wire listed as factory alarm disable to connect the aftermarket to. I'd rather do this myself if it's easy enough as it's difficult to get the time to bring it back to the installer.
Any ideas on how to shut the factory alarm up for good?
The aftermarket alarm is Prestige APS997A if that info is needed.
