Alrighty, then!
After many moons I have acquired all of the hardware components of my install. I still have to get a few odds and ends (and the rest of the deadening), so that left me thinking about how I'm going to wire all my stuff up. I need some way that I can distribute power to devices with smaller (18ga or so) wires and most distro blocks seem to have outputs that are meant to accommodate larger wires.
Here is a very accurate diagram of how I need to distribute the goods. These types of diagrams seem to be popular on DIYMA...
And a little more explanation:
So my question, then, is what can I use to distribute all this stuff? The amp should be fine; I'm more concerned about the other three. I thought about just using a terminal strip since the HD Radio module and camera have inline fuses holders in the wire (I'd just cut the wire so that the fuses are close to the terminal strip); however, the headunit itself (JVC KW-AVX810) has its fuse in the unit body and not in the power wire. I'm not sure if that poses a problem. Also, I don't know if terminal strips can handle the current going to the amp.
Thanks for any thoughts!
- The wire going from the battery, through fuse, and to the distro block will be 4ga. From there, the wire going to the amp will also be 4ga. The amp is fused at 75A, but BCAE suggests that I don't need another fuse here since the fuse after the battery (100A) will protect that wire.[/*]
- The head unit will be connected to the distro block through its harness, which has pretty small (18ga, maybe?) wires on it. My plan is to wire the 12V constant through the distro block and use a Metra harness adapter to get the 12V switched power from where a stock head unit would get it. This goes off the assumption that most of the unit's power while running is taken from 12V constant and the switched line just keeps stuff in volatile memory and starts/stops the unit. Let me know if this is wrong. The head unit has a replaceable fuse in the unit body, but not in the wire.[/*]
- The HD Radio module and the backup camera get their power separately from the head unit from small wires. Each one of these has an inline fuse holder in their power wires. The camera uses a 1A mini-blade fuse and the HD Radio unit uses a 5A mini-blade fuse.[/*]
- I also have a Bluetooth module, but that appears to be powered off the headunit. I would also want to be able to expand this in case I get a processor or something like that in the future.[/*]
