2012 Escape
The drivers seat belt looks new. It is not frayed, stained, or discolored.
A few days ago the seat belt failed to retract. If I gently pull or guide the upper portion
of the belt it does retract. The retractor might be restored to normal function if lubricated.
Prying off the trim panel covering the retractor may not be necessary. An old Escape
Forum post mentioned a lubricant called Jig-A-Loo. It's synthetic, odorless, and does not
stain fabrics. Applying Jig-A-Loo to the seat belt fixed the retractor problem.
Jig-A-Loo is not available in any local store near my home. It is available from Amazon
for $28.99. I've never paid that much for a can of lubricant!
I purchased Blaster Multi-Max Synthetic Lubricant (Part# 16-MM-DS). It does not contain
silicone or lithium and it's odorless. Multi-Max seems like a good substitute for Jig-A-Loo.
Is there any reason I should not apply Multi-Max to the drivers seat belt?
