1 - 3 of 3 Posts
i was driving down a dirt road last night, tryin' to screw off i pulled the e-brake around a corner, but it seemed to stick. even though i released the lever, i could feel it slowing the car down, and when you got out on the right side you could smell it burning up my brake pad.
i was only 2 miles from home so i slowly limped home with it then when i tried to use my brakes i had to push them in all the way, it seemed like there was no pressure and it was hard to stop!
has anyone else had this problem? i'm not really sure how to fix it, and now that there's something wrong with my actual brakes i have a real problem on my hands.
I learned a long time ago that you only pull the emergency brake to perform power slides when you are in a rental car. It sounds like you are going to have to sell your subs and amp to pay for some repairs.
So when you pull the e brake is it loose.? As in its already engaged? Follow the brake line and see if you can loosen it up??? DUNNO?
1 - 3 of 3 Posts
