At Idle temperature increases. 2 fans not on. turning heater on drops temperature to normal.. I dont think thermostat or water pump, since temperature goes down with heater which means there is flow. Is that correct diagnosis?
Is this the order I should check?
Coolant fan fuses
Coolant fan relays
Coolant sensor at coolant output
Coolant fan fuses
Coolant fan relays
