1 - 2 of 2 Posts
Hey i have an 04 escape. someone accidentaly crashed me on the freeway. the radiator and the bumper was the only thing damaged. i took it to a mechanic put a new radiator new and all that stuff..(i dont know much about trucks) but since i got a cheap mechanic, he put the wrong hose on the wrong places. but i had that fixed now. got a new mechanic and he drained out all the oil and put new one. but now..... the engine moves back and forth when i put in in drive. it trembles like the big trucks. what do i do?? i really need the truck for work and fast.. plzz help..
Does it seem like its running rough or does it just shake when you put it in drive? If its running rough I would take it to another mechanic and have them run a diagnostic on it. Sounds either a sensor, or wire was broken during the accident. If it seems like its running fine but just shakes when you put it in drive then it sounds like you broke a main motor mount, transmission mount, or there is a crack in the subframe (unlikely). I hope this helps and you can find your problem.
1 - 2 of 2 Posts
