1 - 3 of 3 Posts
Hello everyone,
I'm new to this forum and found lots of nice info here !!! Still, I am having a problem when shifting (manual transmission) with my 2001 Escape 2.0L. In fact, whatever speed I'm driving in and at whatever RPM, if I press on the clutch pedal and keep it this way, my RPM will increase or decrease (according to the engine speed I was) to about 2,000 RPM for maybe two seconds or so before going down slowly after.
The other cars I had, whenever I would press on the clutch pedal, the RPM would go down right away, so my guess is it's not normal that the engine speed even go up when I press the clutch and get to neutral. But if I'm at a stop (0 mph) and I press the clutch pedal, it doesn't happen, so it is only when the car is moving at maybe 10 mph and over.
So what should I be looking for ??? I have absolutely no clue what could it be.... The car has been doing this since I have it, so maybe 15 000 miles.
Thanks in advance for any input !!!
Only so many things that can make RPMs increase. The throttle, IAC and engine timing but there might be others too. You'd need a scanner to monitor the TPS, IAC and engine timing for a starter.
First of all welcome to the city! :welcome:
Normal operation for mine is when I depress the clutch at higher speed it will not immediately drop down, but kind of hover for a bit then decrease, I suspect it's programmed to do that in anticipation of a gear change.
I've had an issue like what you describe only more severe, and I have the same year/ and Engine as you I believe. I would clutch out and watch it rev up into 3k or so rpm range briefly. It was some kind of sensor but for the life of me I can't remember what it was. It finally got bad enough to trigger the check engine light and it got fixed at that point.
Sorry I can't be more specific. :doh:
1 - 3 of 3 Posts
