verify all components are functioning before assuming it is an actuator. You can look online for a checklist of AC components, and the order in which they should be checked. The failure of one part can cause another to act strangely.
verify all components are functioning before assuming it is an actuator. You can look online for a checklist of AC components, and the order in which they should be checked. The failure of one part can cause another to act strangely.ac electric compressor changed, ac work cold on 60 or 65 degree, once you changed temp to 67 or above, it start blowing hot air, and also no air coming from defrost, when the mode is there, or the ground when changing mood, air only coming from front vents, the dual climate works fine for right or left side, so when left side(driver side), SET AT 60 0R 65 it blows cold from that side, but when right side at 67 or above it blows hot air from the right side, i know there is 3 actuators driver side under dash, passenger side under dash, and one inside dash, but i have no idea which one controls what, and also I don't know are all three are the same part number, I hear the sound of the actuator from right side but not sure the one inside the dash, or under the dash right side, also hear the sound when put the max ac, please help thank you
