Hey there, I hope I'm not overloading or over-posting my info here. I did get a couple requests to help out w/ audio here so I thought I'd gather up all my CAD models and show them here. The idea is that some of these may work out for members here. Also, most of the models are still in my computer, so we can remodel them for different equipment or ideas as needed. Not all of these are for E/M/T's, since some of the ideas are universal.
Here goes:
This was a plan originally created for a Focus trunk. My design goals were to create a system that allowed a spare tire to fit right in the trunk (the car originally comes with the space but without the actual spare!), and still allow for enough trunk space to fit duffel bags. This was eventually scrapped for an amp rack that was mounted under the factory deck, which left room for a more conventional sub box. Still, this was fun to draw.
This is how you can fit two big bad subs in the recess or a spare tire and wheel. Not the spare tire well mind you...but the wheel itself! Still sits pretty tall though:
Looks like this with a false floor
This uses an older Escape (with the spare tire well) and 4 pancake subs.
This was designed using TangBand pancake subs in an older Escape, but allows for a small space for storage in the middle.
This is the older Escape's spare tire well dimensions (with wheel inside) in case people need it
This is for a tiny standard cab pickup. We ended up building a variant of this box and it turned out amazingly well.
Alternate design, with 6.5" mini-subs. We ended up with 3 in our system, but 4 was the original plan.
That's all I found in my archives.
One thing to keep in mind is that I am happy to create a custom cad sketch for all here, as long as they understand it takes a bit of time to make one! Also, having accurate measurements helps a ton.
Take care!
Here goes:
Take care!
