Ok, so I've shown you what the past systems looked like. Now, I'd like to show you the current setup. It is a work in progress, but the core structure and design is in place. I lack some carpet, vinyl, and paint work, but otherwise it is all there. I also need to take more pics of the processor, and front drivers. Still, here goes:
This system is one of my most powerful and uncompromising. I initially was going to do a false floor again, but the subs I chose simply DO NOT fit any notion of stealth due to their massive size. Instead, I went for absolute sound quality while still being able to fold the passenger seat flat if need be.
Equipment (that I remembered to take a pic of):
The sub and main amp look identical in shape.
1/0 gauge wiring kit (and kitteh "Bristol")
The DIYMA R12. All hail the DIYMA. It is a god among subs.
Construction of the new false floor. This time I want something exactly factory floor height, unlike my last build.
Test Fitting
Cutting holes and starting a hinge setup.
False floor installed, and hidden nicely.
The ~1 cubic foot box built for the subs.
Subs mounted inverted, so pretty!
This was a casualty of the build...a misplaced razor blade went under my fingernail and tore the meat up underneath, then exited through the nail.
I still need to do some finish work and I also need to show you the front drivers and processor, but I'll get those later.
Test Fitting
