1 - 3 of 3 Posts
I was searching for fog lights and these are in my price range. I read the description on this product and I am still unclear as to whether they plug into the stock wiring harness for the fog lights. I have an 02 escape xls and though other forums it sounds like the wiring harness for foglights is on every escape whether it was equipped with them or not. I have checked the fog light switch and it is covering a harness plug. So my plans are to order the kit and a stock foglight switch. My questions are, does anyone have experience putting these on? Do they plug into the stock wiring harness? If anyone knows anything I would appreciate it, I just wanted to try here before i try contacting a dealer or the manufacturer. It says it includes 1 wiring harness(all winjet, some x3) does that mean anything to anybody?
Thanks for the help
My understanding with halo lights is that there is a separate switch to activate the halo unless you decide to wire it to the fog light or parking light (but then they would end up flashing with your turn signal). Otherwise, to get the main bulb to turn on, you can just use the regular switch, although some wiring stuff might need to be done.
1 - 3 of 3 Posts
