I took the SC out to diagnose a misfire issue and I have another issue now.
To install the SC, most of the vacuum hoses need to be rerouted. For some reason the top part of the home that leads from the intake manifold down to the PCV valve is caving in and leaking. I'm unsure if the lines are routed the right way and the vacuum line diagram under the hood is not much help, or is the Haynes manual.
So I need a schematic or drawing of the proper vacuum line routing (hint hint, JP).
It seems a cylinder in the rear bank is misfiring, but no engine codes are thrown, but I want to resolve this first!
Any help appreciated!!
