Looking for information regarding ECU/ECM TPMS Relearning, Specifically is this Gen 2 Escape capable of learning & monitoring (5) TPMS Sensors? I have a Full Size Spare with a Schrader 29020 TPMS Sensor. The 29020 is a OER (Original Equipment Replacement) Sensor and it is pre-programmed with the protocol for the 2011 Ford Escape. According to Schrader Tech Support although it is a 33500 Series Sensor, it can not be reprogrammed or cloned.
I have an OBD MONSTER T-19 (Ford) Activate/Relearn Tool to us in case of a flat tire. I have a 2nd set of wheels for mounting Winter Tires. If necessary I will buy a Schrader or ATEQ TPMS Scan/Diagnostic Tool so that I can perform a (5) wheel ECU Relearn. Not certain of the sequence but expect it follows the Stationary Relearn (FL/FR/RR/LR) followed by the spare. Since the Standard Stationary from the manual has no mention of Relearning a spare that I could find, I suspect that for (5) Wheels one would have to use the ECU/ECM Relearn if it is possible.
Thanks in advance for any and all assistance.
