hey I had my mariner maybe a Month and a half and the dealer said the horn has failed...but recently i installed a side lamp bulb and thats when it stopped working..so maybe the dealer doesnt know anything and I just pulled out a wire he said hes going to see what he can do and if its covered but if not ill just take it and remove the grill myself and fix the horn..problem is that i unbolted the two bolts on top of the engine bay and that only unbolts the top of the grill how do i remove the whole grill?
You mean the bumper cover? I don't think the horns are behind the grille; removing that would just expose more of the radiator.
There are instructions for the bumper cover here: viewtopic.php?f=28&t=1734
Breensy said:
yeah the actual horn on my 05 is located right around the passenger side fog light (under the passenger headlight) you can see it by removing the grill. its most likely you just accidently pulled on a connector or something like that.
Breensy informed me in another post it was under the headlights on the passenger side in a 05 mariner and I thought maybe it would be easy to access it through the grill, I tried removing the inner fender wall on the passenger side but i couldnt access anything seems to be plastic coolant tanks there and only access to the fog lights and side bulbs
I last had the bumper cover off around 2007, but I think the grille insert snaps off once the two top bolts are removed.
