1 - 18 of 18 Posts
i like to do the regular maintenance to my cars, you know oil changes, tire rotation, fluids, etc.
the problem that i have is that i haven't been able to find an End Cap Oil Filter Wrench that fits the 09 mazda tribute oil filter.
i tried with the spider-type and clam action, and nylon straps, and the cap is just not deep enough to work with these tools.
at the moment i'm using an end cap oil filter wrench that is just a little big, but i stuff it with paper napkins of rags, to get enough pressure to get the cap loose.
so my question is:
how do you guys change it and what tools do you use?
hope to find some interesting answers...
The Mazda has a service policy, they do it. Sorry, no help I know... :shrug:
If I ever changed my oil filter I'm sure I'd have some very interesting answers. :lol: I trust the service dept. to do it.
I have nothing useful to add. I'm just trolling. Although cussing at it seems to work for me sometimes.
My hand. An oil filter should never be tight enough that you can't use a little elbow grease and get it undone. Although if you have a V6 model like mine, make sure to have a couple rags to wipe off the exhaust manifold. I have yet to find a way to keep oil from getting on it.
I use my Channel lock pliers for oil filters as they're adjustable. I have a 1/2 dozen or so and this seems to be the most versatile. They're in the $30+ range, but you'll be able to use it for many others. Its obviously only a hinderance with tight access area cars.
put a screwdriver through it and twist. its not like you'll ever use the filter again anyways. Then just make sure not to overtighten the new one and you shouldn't have the problem again
+2 on the hand tighten. Oil filters can lock up pretty damn tight if over tightened. The next time you get it off just clamp it down with your hand and itll hold just fine untill you crank it off for a change.
Don't know what you mean by "spider", but this one works great on a 2003 Escape (and any other car I've tried it on with end access):
Available at Sears: http://www.sears.com/shc/s/p_10153_1260 ... ter+wrench
Actually, I find the most effective way to deal with old oil filters is to DRIVE A CAR THAT DOESN'T HAVE ANY!
-SPARKZZ
Walkingchaos said:
^ . . . what is this strange vehicle you speak of which has no oil filter ? wind up car ?
Check his signature pic...
I end up using a regular oil filter strap wrench, but access is VERY limited.
I can turn the filter only a few mm's at a time, but it does come off.
To install I hand tighten.
-SPARKZZ
Quite true! Also true:
An 80's model Izuzu pickup trucks don't have oil filters, nor do the original series 1,2, or 3 Volkswagens... :doh:
Walkingchaos said:
I know i was just joking :)
:doh: That's what I get for getting on the Internet and reading quickly before I go to bed... I miss the subtle things..
BTW - I don't change my own oil anymore. For the $20 or $30 it costs, it's worth it to just let the mechanic do it.
My local dealer always does a multi point check each time the oil change is done, it's good for a little peace of mind knowing everything has had the once over.
first oil change usually ends up with screwdriver being stabbed through and filter coming off as a mangled mess as the factory job on most new cars is REALLY freekin tight. Once past that, due to different filter sizes between vehicles and sometimes limited space, I use some soft rubber oil filter remover cup type thing I picked up years ago. It works the same way as those rubber jar openers and just gives you a lot of extra grip to remove by hand. Works great!
1 - 18 of 18 Posts
