Anyone know how to import pics into my 2010 Ford Escape LTD. I have the built in lcd screen and I threw all my books out into the recycle bin by accident and I can't seem to find any manuals online. Even my local Ford dealership seems to shrug their shoulders as to the replacement of this book. :roll:
Thanks
Warren
OK... that link is just for the main manual. I didn't realize they have supplemental manuals for Sync.
Here is a direct link to the General Sync (no nav) manual - 2nd Printing:
http://www.motorcraftservice.com/pubs/content/~WOA204/~MUS~LEN/43/10sycsy2e.pdf
Here is a direct link to the Sync w/ Navigation Manual - 2nd Printing (The one I think you want):
http://www.motorcraftservice.com/pubs/content/~WOA204/~MUS~LEN/42/10ngnsn2e.pdf
Found these at the Ford Owners site. You should sign up and check it out. Lots of good info there.
On page 23 of the Sync w/ Nav Manual I found the following:
Loading pictures
Your navigation system allows you to save and view up to 32 photos. To access:
1. Ensure that you are on the Home Screen. (Press at the bottom left of any screen to access.)
2. Touch the left side of the home screen to initiate the left screen photo display and saved photos screen.
3. Select the 'Add' button on the touchscreen. The following disclaimer will appear, "Please confirm the supported photo formats".
4. When the pop-up dialog box with the disclaimer appears, press OK and ensure that you are using the proper format.
5. Insert a CD-ROM which contains your photos as jpegs.
6. Press OK. The photos will be listed on the right half of the screen.
7. Select either ADD or ADD ALL.
The photos are now saved to the hard drive.
Photo display limitations:
• The file must be 1.5MB or less.
• The extension of the file must be one of JPE/JPG/JPEG.
• The CD or DVD must be ISO 9660 format, UDF format is not supported.
• The file path must be 255 characters or less.
• Up to 256 files or folders can be displayed in one folder.
• Not compatible with discs written in Packet Write mode.
• Only the photograph(s) which meet these conditions will be displayed.
Note: When burning a CD, ensure that you 'close' or 'finalize' the disc when the CD-burning process finishes (you should select this option before you start burning). Consult your software manual or the program's Help files if you're not sure how to finalize the disc. Also, write the audio data into the first session of a multi-session CD as audio systems won't be able to sort through other sessions to find more audio tracks.
Hope this helps :peace:
Awesome. Thanks RobtRoma. That helped me out a lot. Especially once I registered.
I am so glad I found this forum. Everyone is so helpful here.
You guys Rock! :rockon:
Thanks
