DON'T use hot glue!!!!! Use Singer fabric glue and clean the surface of loose debris first. I then use a screwdriver handle to remove any air pockets, then use a pizza cutter around the edges to tuck the fabric back in. Hot glue will be lumpy and will cool too fast.dcpopo said:Thanks for that, I hadn't thought of a glue gun.
Might be easier to see if you can source some Mazda tribute door panels. They are just hard plastic and there isn't any upholstery to come off. Some model Escapes had the same. I did this for my sister in law and never had to deal with it again.BigT105 said:It seems almost everyone with Older Escspes and Mariners are having issues with the upholstery on the doors peeling off and leaving that nasty black backing and residue behind. I bought the 3M spray adhesive for car upholstery and repaired all four of my door panels only to have three of the four come loose again within a few months. I thought about this issue and I read tons of earlier posts. I had noticed that under the edge of the backing material the plastic door panel underneath wasn't smooth, in fact it had sort of a pebbled/cobblestone look for lack of better words. So I decided to remove all of the old material down to the plastic underneath without damaging the plastic. I used WD-40 to soak about a four inch square area of the backing material. Then I carefully used a razor blade to shave several slits into the backing material. Then I used a wide plastic paint scraper to get the backing material to start coming loose. I again used the razor blade to carefully cut the backing material deeper and again used the paint scraper until I could see the textured plastic door panel underneath. I kept working the same way until I removed all of the backing material. The door panel looks a lot better with the textured finish versus that nasty backing material. I have a few very small areas where there is some leftover backing material still stuck to the panel as well as some white spots of the factory upholstery adhesive. I'm hoping Goo Gone or something similar will remove that without damaging the colored door panel. I have before and after pictures of this, as well as some pictures of the work in progress. I hope this helps other users with this issue.
