Here are the long awaited pictures:
1. Pull instrument panel.Surfscape said:you do a write up on how you pulled off this masterpiece????
You left out the Blizzard gift card.Big Chris said:1. Pull instrument panel.Surfscape said:you do a write up on how you pulled off this masterpiece????
2. Post to JP with a cheque for $50.
3. Wait patiently for return of newly modded dash.
4. Re-install instrument panel.
:lol:![]()
No I did drive it during the time. When the instrument panel is out you will notice a few things:Surfscape said:So was the truck sitting the whole time? How long is JPs turn time?
:lol:Scooter Scott said:You also left out yelling at the United States Postal Service
:bill:
Well... er...Surfscape said:So was the truck sitting the whole time? How long is JPs turn time?
I think I'll just drive my Mav over there and stay with you a few days. Gotta be easier than all this 'postage' malarkey.jpark said:I already did a writeup! viewtopic.php?f=10&t=1361
I'd rate it about a 5 if you've worked with electronics before. Since the LEDs and resistors are all surface-mounted, I'd change that to a 10 if you've never worked with SMDs before.
Also, I finally finished the cluster in my Edge, which is totally different from the 2005-2007 Escape's cluster.
Before:
After:
I took the first picture after I had changed the LEDs in the steering wheel, headlamp, and climate control switches, but before I changed the cluster and the LEDs in the nav HU. To get an idea of how much brighter the new LEDs are, the original dim green LEDs and cluster aren't even visible at this exposure level. I even installed brighter needle LEDs. I just bought a new camera (a Canon A590IS), so I should be able to take better pictures than these. The pictures really don't capture how good this now looks.
