Is Ford lying about PCM Flash for 6F35 Transmission?
11K views 8 replies 6 participants last post by  csonni
You have these service bulletins that are for the 2009 Escape w/6F35 trans.
Service Bulletin No.: TSB-09-19-5
Component(s): POWER TRAIN
SUMMARY:
FORD: SOME VEHICLES EQUIPPED WITH A 6F35 TRANSMISSION MAY EXHIBIT DIAGNOSTIC TROUBLE CODES (DTCS) P0770, P0772, P0773, P0774. THE DTCS INDICATE OPEN, SHORT TO GROUND OR SHORT TO POWER IN SHIFT SOLENOID E (SSE) CIRCUIT. ERRATIC SHIFT AND/OR HARSH ENGAGEMENTS. *PE
Service Bulletin No.: 15-0079
SUMMARY:
FORD 2009-2014 ESCAPE, 2010-2014 FUSION, 2012-2014 EDGE, EXPLORER, 2013-2014 TAURUS: LINCOLN 2013-2014 MKT,MKZ: MERCURY 2009- 2011 MARINER, 2010-2011 MILAN. SOME VEHICLES EQUIPPED WITH 6F35 AUTOMATIC TRANSMISSION MAY EXHIBIT A FLUID LEAK FROM THE LEFT HAND TRANSMISSION HALFSHAFT SEAL DUE TO WEAR ON THE TRANSMISSION CASE BUSHING. *LJ
Service Bulletin No.: TSB-14-0056
SUMMARY:
MERCURY/FORD: ON SOME VEHICLES, THERE IS A FLUID LEAKAGE, COMING FROM LEFT HAND (LH) HALFSHAFT SEAL OF THE AUTOMATIC TRANSMISSION AND A SERVICE KIT IS AVAILABLE NOW, FOR REPAIR. MODEL 2009-2012 ESCAPE, MARINER, FUSION, MILAN. *PE
Service Bulletin No.: SB-44300
SUMMARY:
FORD: ON THE LEFT HAND HALF SHAFT SEAL, THERE IS A FLUID LEAK FROM THE TRANSMISSION BECAUSE OF WEAR ON CASE BUSHING. MODEL 2009-2012 ESCAPE, 2009-2011 MARINER, 2010-2012 FUSION, 2010-2011 MILAN. *PE
Service Bulletin No.: AS-21624
SUMMARY:
FORD: THE TRANSMISSION MAY LEAK FLUID FROM A SEAL. 2009-2010 ESCAPE/MARINER. *RM
Service Bulletin No.: ASI-32332
Component(s): ENGINE , POWER TRAIN
SUMMARY:
FORD: DUE TO AN INTERMITTENT LOSS OF RPM OR LACK OF ACCELERATION, IN SOME VEHICLES, WITH ILLUMINATED WRENCH LIGHT, DIAGNOSTIC TROUBLE CODES (DTCS) P2111, P2112 MAY OR MAY NOT BE STORED IN POWERTRAIN CONTROL MODULE (PCM). MODELS 2009-12 ESCAPE, MARINER, FUSION, MILAN. *PE
Hope this helps
