Issue with Reverse when tranny is warm
6.7K views 3 replies 3 participants last post by  JakeF
#1 ·
Hi guys,
So my transmission is exhibiting some odd behavior. When the engine/transmission is cold, I can start it up throw it in Reverse and it goes right into gear immediately and smoothly. After driving for a bit, if I stop and put it in Reverse it does not go into gear, just sits there like it's in neutral, until the engine RPMs reach about 1,500 then it kind of slams into gear.
This is a new to me vehicle, so I have no idea how long it's been since the transmission has had a flush/fluid change. I suspect probably never, and with close to 200k miles I'm sure it's long overdue.
My question is whether or not a flush/fluid change is likely to remedy this issue with Reverse, or am I most likely looking at additional cost for transmission repair.
2005 Escape XLT 3.0 V6 4x4
#2 ·
You can try a couple drain and fills, and see if the condition gets better.
there are DIY's on this site on how to do it.
If it doesn't help you'd be looking at additional repair to an rebuild, especially since your close to 200K.
#3 ·
I can't speak to the specifics, but in most automatics, the line pressure to R components is higher than that to the D components.
If you increase rpms to ~1500, the line pressure should increase, subject to the control of the computer which regulates line pressure. You could have a bad sensor, a bad pump, or a leaky clutch pack or servo(a piston & cylinder with an arm that clamps onto the end to squeeze a band). ( I don't remember what is 'engaged' in R, and don't want to look it up).
It could be that a solenoid valve is gummy or has some 'stuff' that plugs it a bit, but I don't know the odds.
Most times when a servo 'slams', it is because there was insufficient pressure to overcome the spring that moves the piston back to 'rest' until the pump got going enough.
The above surely didn't answer your question, which I summarize as: Is it broke enough to need rebuilding, or can I swap 'this or that' and have it operate better?
The only things you can swap from outside, as I remember, is the valve body & solenoids, and the speed sensor.
Check your fluid level when the transmission is warmed up completely. It will read overfull when cool, engine stopped, so the engine must be running also.
#4 ·
Thanks for the thorough description, Tomw! I guess low line pressure could also explain why it functions fine when the transmission fluid is cold and slightly thicker, vs when it is hot and thins out a bit.
