OK last update probably for the night. So I on a whim with the caliper as it is opened the bleeder valve and nothing came out of the new caliper. The only way I can get fluid to come out is to take the caliper off and with the brake bleeder open using a clamp to push the piston in and then fluid shoots out. I don't know if this is a symptom but it's at least a reference point. It's almost like the fluid is getting blocked from releasing back up into the line, the hose is new so it has to be beyond that. Could it be the abs distro box where the line connects into? Or is this still looking like a master cylinder or even brake booster problem?
When I crack open the driver side it dribbles out like I'm used to seeing from calipers. This makes me think it might not be the master cylinder because wouldn't it affect both sides the same?
Is there a way to flush the hard line from the master cylinder distro box to rule out a blockage there? I don't think there is one because with the bleeder loosened I can bleed the caliper and fluid squirt out its like there is a valve closing and not allowing return of fluid only delivery to the caliper is this a possibility?
Edit
Just had a laying on the couch contemplating why I don't buy cars with warranties idea. Could I leave the brake bleeder closed and undo the brake line from the distro box and then try to clamp down on the caliper piston and see if it will collapse? My thinking is that if it indeed collapses and fluid shoots out of the line then I can move to the brake master cylinder itself, reconnect the line to the distro and connect everything back, pump up brakes till its stuck again and then this time remove the line from the master cylinder, if it again allows me to collapse the piston and fluid shoots out of the line from the distro to the master then I've successfully narrowed down the problem to the master cylinder. Or is this crazy?
Edit
