Where can ci get flush mounted LED's i ahve been searching the internet for them and local junkyards for crashed 09/10 escapes with ambient lighting and no luck so far i have been searching since august and no luck
I'm going to try to find the part numbers for the LED assemblies that Ford uses in the factory ambient lighting package. The accessory package is not the same as the factory package, since it's designed to fit dozens of different vehicles.
As far as aftermarket lighting, if you only want one color, Digikey carries dozens of different though-hole LEDs that can be added to the instrument panel lighting.
http://search.digikey.com/scripts/DkSea ... mm%20panel
Remember to add resistors if the LEDs aren't rated for 12V.
okay thank you... I am trying to get leds that are similar if not the same as the lighting for the instrument cluster along with the a/c unit and stero...I dont know how well that will work out though
there is a post on changing the instrument cluster leds in elec mods already it has a couple things about where to get them and how to do it
