hi all,
i have a 08 mariner, i need to replace the light for the rear plate, how do i change the socket,old one is broke, i got the back cover off but having a hard time trying to get the pc that has the rear emplened off.
Thanks
Are you saying the actual plastic light bulb socket is broken? If it were me: I'd head to the parts department at your local Ford dealer and order the replacement item. Then from there, you should see how it clicks into the tailgate... Which would then allow you to apply proper plier pressure to remove the busted one.
yes its that one, but my problem is tracing the wire, i dont want to splice it, i was able to remove the back tailgate cover but the piece where your emblened is on the outside of thr truck cant get that off.
Oh I get it... You need to remove the rear door bezel above the plate. Uh, I have no idea on that. Time for a shop manual.
