I have some parts left over from a recent engine rebuild and stuff laying around.
A connecting rod fastener failed causing it to break loose and punch a hole in the block.
V6 Engine Parts:
Complete top end (heads, rockers, camshafts and valve covers) - Make offer
Front cover with tensioner - Make offer
Chains, lower sprockets, hydraulic tensioners, chain guides - Make offer
Assorted nuts and bolts - Free I guess. Let me know what you need
Damper - $30
Coil pack (Used but known to be good) - $10 each
Oil pump (45000 miles on it) $30
Oil pan - $50
Set of piston and connecting rod (45000 miles on them) $50 each
Injectors - 16lb (should be cleaned since they came from a used engine) $10 each
If you see something else you need in the pictures, let me know.
4 Cyl Engine Parts:
Full set of engine mounts. Bought by mistake - make offer
Alternator for 2,3 L Engine. Again, bought by mistake - make offer
Kenne Bell Supercharger:
1.5L SC for 01-04 Escapes and Tributes. It's being sold for $2500 shipped. Add 50 to 60 HP at the wheels in an afternoon. All necessary hardware and literature included.
Freebies:
Full XLT Center Console. The lid leather needs to be redone. If you are converting from a XLS, you need the XLT handbreak mount.
I will continue to add stuff here. I still have a couple of more boxes to look at.
Everything ships from San Juan, PR
Visit this webpage for pictures and more details:
http://www.xcapepr.com/iweb/Engine.html
V6 Engine Parts:
Damper - $30
Oil pan - $50
4 Cyl Engine Parts:
Freebies:
