anybody know how this sounds......are the speakers decent? should i add a subwoofer and amp first or change the head unit?
I assume you mean the 320 watt 7 speaker system? If so, I am pleased with the sound. Nothing too much but my 14 year old says it is "ok" so I guess that is a green light from a teenager.Jordan31 said:After doing a bit of research, I'm pretty sure the mach 300 system already has components in the front and a stock subwoofer as well as the cd changer.
I'm sure someone else can verify this, as mine was just a basic stock stereo.
As for sound, I'm sure its decent, still a factory setup though, If you upgrade, you will definitely hear a difference.
If you plan on adding a larger subwoofer and amp, I would say the best way to go would be to upgrade the headunit first, This would be the easiest way.
I'm not even sure how to add a sub to a factory cd player.
What are your plans for the audio system? We might be able to help you out a little better with some more info.
I can list off prices of my setup, I'm 21, if your close to the same age as me you might have similar opinions about sound quality. Anyways this is what I would call a really good setup, and is nowhere close to the most expensive stuff.05escapeny said:i just want to have a really good sounding system....
