ive ordered 3 different computers all from dell. sight unseen. and have not had a problem yet. knock on wood i havnt needed a repair after the warranty was up LoL.
11!jhande08 said:JPark, let me be the first to ask then... WHAT'S YOUR SHOE SIZE??jpark said:That's what really ticked me off on that last trip. It asked me for everything but my shoe size every time there was a glitch in the wireless connection.
:cuss: :censor: :wall: :cuss: :censor: :wall:
:hyst: :hyst: :hyst: :hyst: :hyst:
Why go thru all that? I just turn it off. Control Panel/Administrative Tools/User Accounts/On or Offcbramsey said:I was bored yesterday. I decided (for whatever reason I am not sure) to upgrade my Win XP based laptop to Vista Home Premium. I followed the instructions explicitly provided by my laptop manufacturer Toshiba.
For the most part, the install went well. As part of preparing for installing Vista, all of the utilities that were XP-based were uninstalled. The DVD burning software was uninstalled. When it was removed, Windows XP decided I didn't have a DVD drive anymore. I even lost reference to the drive letter :shrug: .
It took about 3 hours to figure out a workaround. :wall: :wall:
They say a Vista install takes from 3 to 6 hours. Including my adventures with the stupid DVD drive letter, I spent between 8 and 10 hours installing this new OS.
I did figure out how to turn off the User Account Control.
There are several methods to do this. I chose to use the Registry Editor.
Using Registry Editor
1. Run Registry Editor by typing "regedit" in Start Search or command prompt.
2. In Registry Editor, navigate to the following registry key:
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\
CurrentVersion\Policies\System
3. Locate the following DWORD registry subkey in the right pane:
EnableLUA
4. Right click and choose modify or double click on EnableLUA to modify the setting. On valud prompt, set the new value to 0.
5. Exit from Registry Editor.
6. Restart the computer.
To enable the UAC again, simply change back the value of EnableLUA to 1.
That is what I do also (about five minutes after I finish the install......)MadMax said:Why go thru all that? I just turn it off. Control Panel/Administrative Tools/User Accounts/On or Off
I ordered my pc from http://www.cyberpowerpc.comCrashNburn said:ive ordered 3 different computers all from dell. sight unseen. and have not had a problem yet. knock on wood i havnt needed a repair after the warranty was up LoL.
I figured that out later on. Just had to do things the hard way.jmorton10 said:That is what I do also (about five minutes after I finish the install......)MadMax said:Why go thru all that? I just turn it off. Control Panel/Administrative Tools/User Accounts/On or Off
~John
What kind did you have? What kind did you get?cbramsey said:I figured that out later on. Just had to do things the hard way.jmorton10 said:That is what I do also (about five minutes after I finish the install......)MadMax said:Why go thru all that? I just turn it off. Control Panel/Administrative Tools/User Accounts/On or Off
~John
BTW, that laptop died this morning. I am not sure if it was Vista that killed it or not.
So I got a new laptop today. :woohoo:
Just got back online and updated. God, what a pain!!!!!!!
The reason was to choose the most difficult way to turn off the darn UAC!!! ;-|MadMax said:Why go thru all that? I just turn it off. Control Panel/Administrative Tools/User Accounts/On or Offcbramsey said:I did figure out how to turn off the User Account Control.
EnableLUA
I had Vista on for a week, there was a driver for the soundcard it works ok but the software for it did not work, the software contians the EQ programs. Software for my scanner and printer did not work also. When I am on Palktalk or Yahoo I would freezed up or my sound does not work. So a week later I reinstalled my XP PRO back on.Scooter Scott said:The aesthetics of Vista is great! But sadly I ran into a lot of problems.
1st...DRIVERS This is always an issue. I can't get any programs to run on my machine that I regularly use. I am in the process of reinstalling XP on my machine right now
2nd Memory Hog! This OS uses tooooo much memory. Whenever I would look at the stats of my machine it was constantly working harder than it should.
3rd User Account Control is annoying! Everytime you click on something, Vista asks you if you want to open that item. Well DUH!?!? Isn't that why I clicked on it in the first place?
Overall..PITA. Stick to XP![]()
Sorry to take so long to answer. I missed your query.MadMax said:What kind did you have? What kind did you get?
I use those fans also, I have a super powerful tower (it has 4 15,000 rpm Seagate Cheetah's/dual channel Adaptec scsi controller etc etc etc in it) & with those fans it is almost totally silent (unlike some of my old beasts that sounded like a jet engine taking off)jpark said:Search for "NMB" fans at NewEgg. They're the only fans I use. They not only last forever, but they're very quiet. Almost all of the noise they generate is air, not motor noise, and if you buy the low-RPM versions, you won't even hear much air noise.
Hi Scott. I am running the 32-bit version, Vista Home Premium, on my laptop. No problems and have had it about a year. Anyway, please keep us posted on how the 64-bit version is working for you. :yes: I may consider an upgrade if it is worth it.Scooter Scott said:Someone tell me why I just reinstalled Vista? lol except this time I am trying out the 64-bit version. Which just a first thought...this OS runs sooooo fast and I'm not lying!
