Let me start by saying I am not an expert nor do I claim to be! Those of you that are experts please give ideas.
I started by wiring in the amp. Then removing the factory compartments in the rear floor.
Next was to make the bottom of the enclosure. Keep in mind the floor of the Escape is uneven and has several high spots.
Then the sides and the top. I used the factory carpet for the outline of the top and angled the enclosure to be sure there was no lip when you load things into the back. The front is higher because I made this bax for a standard sub, then replaced that one with a shallow sub.
Next was to put the two halves together and test fit into the car. Notice the build up around the hole. That is so the sub can be recessed into the box and the carpet installed over top so it is completely covered.
Then carpet and install.
Fit the sub, put on protective cover and put in factory carpet.
This was done with all stuff I had laying around. It took about a 4x8 sheet of mdf. It took about a weekend to get everything done including the wiring and interuptions. It adds alot to the factory system, without being overpowering.
The pic in my sig was what I had before, until my wife started to grump about not being able to put groceries in the back.
