1 - 9 of 9 Posts
OBD codes P0012 & P0022.
I just picked up off lease 2009 Escape XLT 3.0 fwd.
I have had it for 4 days and the check engine light came on with the above codes.
Can I assume its the cam shaft sensor that needs replacing ?
Thanks (first post here).
Tom
Tom
TSB 09-13-8
3.0L ENGINE MIL ON - DTC P0011, P0012, P0021, P0022 - BUILT ON OR BEFORE 4/22/2009
Here is the full TSB:
TSB 09-13-8
Publication Date: June 24, 2009
FORD:
2010 Fusion
2009 Escape
MERCURY:
2010 Milan
2009 Mariner
ISSUE:
Some 2009 Escapes, Mariners, 2010 Fusion and Milan vehicles equipped with a 3.0L engine and built on or before 4/22/2009 may exhibit a malfunction indicator lamp (MIL) on with diagnostic trouble codes (DTCs) P0011, P0012, P0021 or P0022. This issue may also cause P034X codes to be present.
ACTION:
SERVICE PROCEDURE
Using IDS, verify DTC's.
Verify vehicle build date was on or before 4/22/2009.
If the vehicle was built after 4/22/2009 do not continue with this procedure, refer to the Powertrain Controls/Emissions Diagnosis (PC/ED) for normal diagnostics.
If the vehicle was built on or before 4/22/2009 proceed to Step 3.
Follow Workshop Manual (WSM), Section 303-01B to remove upper intake manifold, right hand (RH) and left hand (LH) valve cover's.
Replace both bank 1 and bank 2 variable camshaft timing (VCT) solenoids. Follow WSM, Section 303-14B for VCT solenoid replacement procedure.
NOTE: IF THE VEHICLE HAS LESS THAN 30,000 MILES (48,000 KM), THEN THE INTAKE GASKET AND SPARK PLUG WELL GASKETS CAN BE REUSED. INSPECT AND REPLACE ONLY IF DAMAGE IS VISIBLE. IF THE VEHICLE HAS OVER 30,000 MILES (48,000 KM), REPLACE INTAKE GASKET AND SPARK PLUG WELL GASKETS AS DIRECTED IN WSM. IN ALL CASES THE VALVE COVER PERIMETER GASKETS MUST BE REPLACED.
If the P034X codes are not cleared by this procedure, follow normal PC/ED diagnostics.
PART NUMBER PART NAME
9L8Z-6M280-A VCT Solenoid
9L8Z-6584-A RH Gasket
9L8Z-6584-B LH Gasket
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
OPERATION DESCRIPTION TIME
091308A 2010 Fusion, Milan 3.0L: Replace Both VCT Solenoids Includes Time To Check DTCs (Do Not Use With Any Other Labor Operations) 2.8 Hrs.
091308A 2009 Escape, Mariner 3.0L: Replace Both VCT Solenoids Includes Time To Check DTCs (Do Not Use With Any Other Labor Operations) 2.1 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
6M280 42
That TSB info is messed up! How can vehicles built before 4/22/09 include the '10 Fusion and Milan? I know they were mid-year but didn't think that they were building them that early in '09!
Just got it back from the dealer. Performed the TSB. Since my mileage is 37,000 kms, they wouldnt pay for the intake or plug seal gaskets so I said I would. You know...while its apart anyway....$50.00 my cost no labour.
Thanks for the help.
How long did this repair take?? I brought my escape in for the same issue and they are telling me that if i drop the car off this monday at 7am I will get the car back tuesday afternoon. That seems a lot longer then 2.1 hours!!!
What would happen if the VCT solenoids are not replaced? I am having the same issue. I plan to replace them, just curious.
When I checked the codes at Autozone, the guy working there ran the code and the possible causes to the error code was using the incorrect weight oil. Anyone think this could cause the issue as well?
1 - 9 of 9 Posts
