As noted, the only oil that might be inside the plenum would be from a leaking evaporator. If the A/C works properly and is cold, it is unlikely that the refrigerant R-134a, has leaked out. The refrigerant carries oil around the system as it moves, providing lubricant for the compressor pistons. If you leaked refrigerant you'd likely leak oil. If it was leaking at a fitting, in most cases the oil that is carried out by the refrigerant will leave a film that will attach road dirt and grime, causing a dark film to form around the fitting. If you have dark, dirty spots at fittings, you are likely observing a slow leak. Soapy water sprayed on might disclose slow bubbles... FWIW.
