So is the leak only on one side? If it's on the passenger side it could be the crankshaft seal. Make sure you check before changing the oilpan gasket
Okay so its only a handful of bolts to remove. I would probably take a good mechanic no more than half hour to remove and replace the gasket. Maybe an hour total for draining oil and removal and replacing the pan. I would say they will charge you for 1-2 hours labor plus materials.
ohh I just looked under the car while trying to track down an oil leak near the crankshaft and noticed that youll have to drop the exhaust. But it doesnt look too bad. still only 2-3 hours labor.
