1 - 15 of 15 Posts
Hi Fellas,
This is my first post so forgive the blandness of my page. I have an 07 Ford Escape XLT V6 4X4. I recently found that I could start a "test" by pressing and holding the ODO Reset button and turning my ignition switch on. Does anyone know where I can get a list of what the different readings represent? I can only decipher a few of them.
Thanks
Don
Hi there and welcome to the forum :)
I found this on another website not too long back. Hope it helps.
Here's How:
1) Insert Key (do not turn it)
2) Press and hold the Trip-Meter Reset Button
3) While holding the reset button, start your car and continue holding the button.
4) Within 10 seconds, the display should change to "test" (written in a silly LCD font) and the needles will go nuts. No biggie. Release the Button.
5) Pressing the button will now cycle through some 15 different modes.
The modes you can go through in the Escape are:
1. Gauge Sweep
2. Fill in All LCD
3. Indicator Bulbs
4. ROM level
5. NVM level
6. DTC (Diagnostic Trouble Codes)
7. Road Speed MPH
8. Road Speed KPH
9. Engine Speed RPM
10. Fuel Volume
11. Engine Coolant Temp
12. Battery Voltage
13. ABS fail
14. Electronic Brake Distribution Failure
15. Illumination
16. Crank Sense
Here's a more complete listing:
Code:
Seq...Display.....Description
1.....GAGE........Full deflection sweep
2.....all.........Odometer segment check
3.....bulb........Warning light check
4.....r...........ROM level
5.....NR..........ROM level and type
6.....EE..........EE level
7.....DT..........Manufacture date
8.....CF1.........1st byte configuration setting
9.....CF2.........2nd byte configuration setting
10....CF3.........Not used
11....CF4.........Not used
12....CF5.........NVM configuration
13....DTC ####....Cluster diagnostic trouble codes
14....E ####......Speed MPH
15....####........Speed KPH
16....t ####......Tach RPM
17....F ###.......Fuel level ratio
18....FP ###......Fuel level
19....### C.......Coolant temperature degrees Celsius
20....odo ###.....Odometer input
21....tr..........Trip odometer miles
22....Ebd.........ABS EBD status
23....ABS.........ABS TT status
24....bAt ##.#....Charging system voltage
25....HSd.........High voltage shutdown status
26....tnS.........TNS switch input
27....d ###.......Dimming switch input
28....rhS ##......Dimming value
29....iin.........Ignition key-in status
30....HLP.........Headlight switch status
31....door........Door ajar switch status
32....Stbt........Seat belt status
33....FF0G........Front foglight status
34....rF0G........Rear foglight status
35....F0GF........Foglight relay status
36....Prnd........Gear selector display value
37....PaR.........Park interlock solenoid status
38....Cr..........Run/Start sense circuit check
39....AC..........Run/Acc sense circuit check
40....ArbC........Airbag chime status
41....Ch..........Last/current chime source
42....CHE ##......MIL input
43....LCL -X......Low coolant level switch
44....CS XX.......Charging system status
45....thFt........Theft indicator light
46....od..........Overdrive-off status
47....CC..........Not used
48....PA-PD.......Port A-D readings
49....PE0-PE7.....Port E0-E7 readings
50....PF-PH.......Port F-H readings
thats a sweet feature, didn't know it was there.
does it work on 03 models too?
Yup. It has worked on every Ford digital odometer that I have tried, including the cargo work vans. The boss wouldn't stop playing with it after I showed him.
thats a really cool feature, they should make it more obvious to their customers
I don't think it will display trouble codes. I find it amusing to play with and if I had an issue might be able to use some of the info to see what the computer thinks is going on, but for full interface you would still need an OBD II cable connection to an appropriate device, in my case a laptop running software that can read it or some dedicated handheld.
1 - 15 of 15 Posts
