1 - 8 of 8 Posts
I tuned up my 2005 Escape 2.3L and gapped the NGK Iridium plugs I bought to .055 as my Ford SM says .052-.056. I have a ScanGauge and I noticed my mileage went down after the tuneup, especially on the highway. I checked the gap on the plugs I took out and they were gapped to .050. I pulled my new plugs out and gapped them down to .045 and mileage went up better than before the tuneup. The following numbers are overall, highway/city combined but mostly highway as my daily commute is 23 miles:
Before tune-up = 25.5 MPG
After tune-up = 24 MPG
After regap = 27.5 MPG
You might try this on your Escape if you are looking for more MPG - YMMV of course but at least it's free.
Interesting, I wonder if this would apply to the 3L V6?
YMMV = ?
YMMV = Your Mileage May Vary
They were gapped way down, like .035 as I recall. I don't trust any plug that is pre-gapped anyway. I always check the gap no matter what.
I just put those ngk iridiums in a couple weeks ago. I should check the gap.... I always heard gapping them could break the tips off...were they brittle at all?
i put in iridium plugs last weekend, and i did the same as i did when i bought the escape.. just put them in. i didnt gap them. i trusted the manufacturer.
The center electrodes are very, very thin so you don't want to pry against it to widen the gap. If you make all your adjustments on the negative electrode only you will be fine. I have installed several sets of these plugs in various Fords over the years and I have never had a problem regapping them.
Some plugs fire differently and shouldn't be gapped to OEM specs, or at least that was the impression I got from GM. Emails from them have stated that the older RapidFire plugs were specially gapped from the factory and should not be adjusted, but the redesigned RapidFire plugs should be gapped to OEM specs. :shrug:
1 - 8 of 8 Posts
