Welcome to the How-To: Articles forum! Before you post, make sure you are posting a guide for others to follow. If you would like to request a walkthrough on a project, make a posting in the How-To: Requests forum instead. For simple troubleshooting, post in the main Problems and Solutions forum.
If you have done an aftermarket modification or want help with an aftermarket modification, post in the appropriate "Mods" forum instead, which are listed below the 'Product Reviews' forum.
Titles should follow this format: '[Applicable years] [Applicable models] [Article description]"
Applicable years - If your article applies to all years, label it '2001-all'. If your article starts at a model after 2001 but applies to all further models to date, you can label it '2005-all', for example. Otherwise, note the start and end model years that your guide may be used for.
Applicable models - If applicable, indicate the drivetrain (i.e., "Hybrid," "V6," "I4," etc.). If the guide applies to only one or two of the triplets, indicate the model (e.g., "Escape"). If the guide applies across the board, then you may leave it blank.
Article description - Write a concise but accurate description of what your guide is about (e.g., "Transaxle Removal").
The title guidelines are there to make the forum easy to search and browse. Don't worry, if you create a title inconsistent with our guidelines, we will correct it for you.
The body of the article would preferably be in numerical step-by-step format. If you want to write it in paragraph format, it needs to be descriptive and easy to follow. Be straightforward enough so that someone could follow a printout of your article while working on their car.
