SUVord said:
For automobile engines equipped with a knock sensor one may take advantage of using higher octane gasoline, (petrol), if more power is to be achieved.That is because the sensor will not decrease the ignition timing too much.And within some limits, the higher the ignition timing the more power, at a cost, you get from your automobile.
As for sensing the benefits of using higher octane fuel you have to be patient for at least a couple of tank fulls until the whole system is accustomed to it.
One more benefit of the higher octane fuel is that it is more free of unwanted and energy wasting residues like the ones you find in regular gasoline.
A properly working knock sensor is starting to operate at the highest possible ignition timing sending command mode and then it starts decreasing the timing to compensate for the gas used.
One may easily verify that, with the appropriate cost involved, if he or she takes the car for a dyno test with a certain fuel and after two or three tankfuls the same dyno is used for the measurements.
I'm afraid that this is incorrect. Using higher octane fuel above the minimum recommended will not increase your power - your engine has a fixed compression ratio, and it would need a higher compression ratio to take advantage of the power increase of higher octane fuel. The knock sensor will not let you take advantage of higher octane fuel, either, unless you are already using octane below the recommended minimum, or you have some other problem with your engine.
The knock sensor is basically a microphone, and when it hears pinging, it
[email protected] the ignition timing, which prevents detonation, and actually
reduces power significantly. If your engine is in good working order, and you use the minimum recommended octane, you won't have any pinging. Therefore, putting higher octane gas in your car will not have any effect on the knock sensor, since there was no pinging in the first place. Even if the knock sensor did have a response, it would never be to advance the ignition timing. It always
[email protected] timing, which always results in decreased power.
I am having a little trouble understanding some of your English, but the only way to take advantage of higher octane fuel is with a completely revamped air/fuel program in your ECU. Even then, this will not give you nearly as much additional power as having an engine with a physically higher compression ratio, but the only way a knock sensor would ever give you more power is if you have some severe engine problem that you are masking by
[email protected] the ignition timing to the point that the engine runs smoothly.
If you have dyno tests that show a properly tuned car with a stock ECU getting significant power gains from higher octane fuel, I'd love to see them.
Here is a good basic article about how octane work:
http://www.oregon.gov/ODA/MSD/docs/pdf/ ... e.pdf?ga=t
