Yes same here. I get good millage just seems strange to me that it drops so fast. At first I thought I was not getting it filled all the way. So took a gas can and filled it till it was running out of filler tube. It did the same fast drop, so have just lived with it. Glad to know someone else has the same trouble. Have a Happy Easter!!!escaping05 said:Don my 05 does that to sometime not even 5-10 miles and it drops like you said. Seems to be stable the rest of the way don't you think?
:thumb:Suprawill1 said:Not really a consumption problem. This is more in the line of physics.
The fuel tank in an Escape is smaller in capacity on the top than in the middle and bottom. It takes less time to consume the fuel in that smaller portion of the tank. Consider a longneck beer bottle. (not how the actual tank is shaped of course)
The neck is probably 1/3 of the total height of the bottle yet you can probably empty that portion with a sip or two. In a fuel tank, the gas gauge float doesn't know that so it just reads the level accordingly.
Hope that explains.
Will
Happy Easter!escaping05 said:Don and will thanks for the info. I never knew the tank was shaped like that great info. Thanks have a nice holiday too!
:thumb:N6CRV said::thumb:Suprawill1 said:Not really a consumption problem. This is more in the line of physics.
Hope that explains.
Will
My car routinely has this problem, 2006 Escape. It's only from one gas station though, but it's the convenient one on my way to work. I rarely can fill up there because it's such a pain in the ***. And it doesn't happen with my wife's Wrangler at all there. Even weirder, they just got new pumps installed there and it still does it.Manic Mechanic said:I believe your year Escape is covered by this TSB, I have done the fix several times ... takes only 15 minutes or so - only a few zip ties required.
http://engine-codes.com/uploads/ford/08-5-5.pdf
