1 - 3 of 3 Posts
Hey guys i'm new to the site and have my first questions.
I own a 2003 limited (new to me)that does not have a rear 12 V plug. I bought one from a junk yard from a TRIBUTE and i would like to install it. before i opened the back plastic panel i was hoping that all i have to do is to dremel the hole in the plastic and plug the socket in the existing wiring but the problem is i don't have the wiring for the plug.I expected to find the same wiring harness like the Tribute from the junk yard had(well at least in the back)
So the Q's are :
(1) Do i hook up to a wire that has constant 12 v or do i run a wire from the front plug to the back.
(2) Do i have the wire for the plug in there and i don't know?
The thing is i want to know that the plug is fused with at least 15 A and when in use it does not overload something else.
Thank you all.
edit: english is my second language so please excuse the spelling.
Your English Is good. Your right all you have to do is dremel and install. Yes all you have,to do is run cable from the existing socket which Is 15 or 20 amps to your new one.
1 - 3 of 3 Posts
