Your idle speed is computer controlled. I recommend cleaning the throttle body and see if this addresses your concerns. Search YouTube for the best ways to clean a throttle body.
There's literally a box connected to the gas pedal, and the only thing coming from that box to the engine is a wire, an electrical wire. It then plugs into the side of the throttle body, I would assume actuating from there the butterfly valve.Your idle speed is computer controlled. I recommend cleaning the throttle body and see if this addresses your concerns. Search YouTube for the best ways to clean a throttle body.
Hello, you also have an electronic throttle. The part you had pictured does not fit your vehicle.Also I would like to ask if anyone can help me locate a specific part under the hood of my 2009 Ford escape XLS 4 cylinder 2.5 L. The Idle Air Control Valve
