Preface:
Planning on moving out of state, so I was just looking for an suv in the same price range as a 1-way Uhaul(around 5k). My only requirements were: it needed to be 4x4, rust free, low miles, moonroof.
Vehicle:
2004 Escape Limited V6
4x4
123k miles
Roof Rack
Running Boards
Stereo
Paid:
$4600
The body/undercarriage are in immaculate condition. Not a speck of rust. Apparently it's been in a dry climate its whole life. The interior has light wear and tear appropriate for the age. It ran beautifully on an almost 3h drive home on the freeway, and other than a beeping from the dash that eventually goes away, and an oil leak, I wasn't worried. Right off the bat, I knew Id be dropping some money since I wanted all the routine maintenance done asap, so id have a fresh baseline moving forward.
Just got a call from my mechanic...
Any words of encouragement? Lol.
Vehicle:
4x4
123k miles
Roof Rack
Running Boards
Stereo
Paid:
$4600
- Every seal that can leak oil, is leaking. (mech says just replace the seals in vicinity of more important fix's)
- The airbags are non-op due to a sensor/module that'll be big money to replace. (That was the beeping, not a dealbreaker)
- Accessory pully's need replacing(routine)
- Rear shocks need replacing(routine)
- Water pump(or maybe power steering pump) needs replacing(routine)
- Spark plugs(routine)
