I'm looking for an after market fender flare that I can install on my 2012 E.
I'm from Canada and these vehicles starts to rust quickly in the same spots
any leads would be appreciated
Jacques
Winnipeg
I don't think there were any made specifically for the 2008-12 escapes.
However, there's universal ones that you can purchase and cut to size, that's probably the best bet here, especially since the rear door falls under the fender shape anyways.
just an opinion, a fender flare will only hide the problem, and exacerbate it. I would recommend sanding what you can, using rust converter as a base coat, a couple of coats of paint, and then plasti dip where you want your fender flares to be. That will at least allow you to see if the problem is ongoing, and needs to be addressed again.
