1 - 7 of 7 Posts
When trying to unlock my Escape with the key or from the inside, it will not unlock the rear hatch, or hatch window, it will only unlock it with the remote. Its not really that big of problem because I usually use my remote anyway, but are there any known solutions to this problem? I would like to get it fixed before I get my new Escape.
Mine only unlocks from the remote also, not too sure about what could cause your prob though
btw, are u selling ur AVS deflectors with ur escape or seperately?
Now it won't even unlock with the remote all the time. And I was planning on selling the deflectors with my Escape(when the time comes). Depending on what year I buy, I might keep the bug deflector.
Just a thought here, but...........maybe it's the battery in your remote? :) When was the last time you replaced the battery? They don't last forever.
You want to open the hatch when you can, pull of the inside trim panel, (4 screws) and look at the linkage. It might very well can be broken, bent and or you have a bad lock solenoid. These can be replaced. Search the forum for help and instructions for this.
I am probably misunderstanding this hatch question, but what I'd like to know is whether there is an inside hatch release anywhere. I have a 2011 Escape and cannot find one anywhere. I can't believe you can only open the hatch and rear window from inside the car by using the remote. All cars I have owned previously have had an inside release somewhere.
Thanks
Battery is brand new, but the problem is that us doesn't unlock from the inside too all of the time. So it may be something on the inside of the hatch.
Thanks
As far as I know, Escapes do not have a hatch release on the inside, which wasn't one of Fords smartest ideas, but you have to live with some things.
1 - 7 of 7 Posts
