1 - 9 of 9 Posts
For reference, i have a 2003 Escape,V6, 4WD. It started with the left rear, but now neither rear turn signal works. I have all other lights- brake, parking, back-up, etc. The signals flash fast, and the fronts are working. I replaced bulbs and checked sockets and all wiring I could see. I used a test light and found no power to those sockets. I would have thought fuse, but the front signal bulbs are working. What am I missing, guys?
Per the first diagram, the power source common to both comes from the CJB, central junction box. I would be looking for the power/ground on C1413 and C1416, and if either/both are missing(bet no power) I would be at the source on the CJB. It is possible the conductor has suffered corrosion, physical damage, etc between the junction box and the last connector before the socket.
Welcome to the city, Ray
Everybody else is on it, usually when it flashes fast, there is a bulb out.
This cascade failure is also typical of rodent lunch
You need to find on the body, the spot that the rear TS light wires separate, and investigate.
I think it all runs together down one side of the body, and they run a jumper harness over to the other side of the body. Not too familiar with your year... and which side skin you'll have to peel. In my 2020 is the right side
actually, the 2009 was also… I will stick with the right side skin disassembly, you will need a panel popper
I appreciate all your help, gentlemen. Apparently, it was bulb fault. I got aggravated and just replaced every bulb in the rear, and everything is working properly for the past couple days. It's strange that replacing the bulbs that were not working did no good, but replacing all of them fixed the problem. Electrical circuits are tricky sometimes. Again, I thank you all for the suggestions. Be blessed!
1 - 9 of 9 Posts
